Weird vibration
Weird vibration
got new tires installed with road force balance.i was getting some vibration at 80 miles so i took it to another place.had alignment and another road force balance..now the steering vibrates starting at 65miles...i asked them and they redid the balance with no change on the vibration.
HERE COMES THE WEIRD STAFF..I NOTICED THAT SOME TIMES I AM CRUISING AT 65 WITH NO VIBRATION.I LET GO OF THE GAS AND THE STEERING STARTS VIBRATING.I STEP ON THE GAS AND THE VIBRATION GOES AWAY..ANY IDEAS?
How many miles do you have on your car.
I would check 2 other things.
1. Check to make sure none of your wheels are bent.
2. Check your lower control arm compliance bushings. Don't be surprised to see some cracks. If they are torn it can lead to vibrations.
The TL is not the easiest car to balance so you almost have to make a list and go through each one.
Good luck.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
kb1rl
Sep 30, 2015 10:17 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
