Weird suspension/tire situation
Old Feb 2, 2011 | 09:35 PM
lazytik's Avatar
Hello,
I searched! I'm just confused...help a noob out please.
My car's steering wheel is slightly to the right...it just turns that way a bit even if the car is driving straight. So...I had an alignment done. That lasted about a day and the wheel was back to being off center.
The car also has a slight vibration (very slight) at speeds. I had the motor mounts changed the vibration def. has improved.
I can also feel a very slight clunk in the steering wheel. I can't hear it...only on inclines...but I can definitely feel it.
What do you think it could be? End-links? CV?
Old Feb 3, 2011 | 02:46 AM
Tommys TL's Avatar
did you check to see if the tires were even?
Old Feb 3, 2011 | 06:55 AM
lazytik's Avatar
They are brand new with about 500 miles on them. Had it aligned after the tires were put on...and then again a couple of weeks ago. Noticed a lot more vibration this morning while driving.
Old Feb 3, 2011 | 02:27 PM
dwb993's Avatar
Torque your lug nuts first to see if that helps. Start with the cheap fixes first.
Check to make sure you did not throw a wheel weight. That kind of stuff.
Dec 7, 2020 05:39 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Skirmich
Oct 1, 2015 12:59 PM
kb1rl
Sep 30, 2015 10:17 AM
jaimbot
Sep 17, 2015 09:25 AM
