Weird sound from engine??
Old Apr 27, 2009 | 09:45 AM
salu8819's Avatar
"Let's Do This"
For the past two week ive been hearing a bird chirping sound from the engine when im at a stop. What the hell is this sound?, its low but u can hear it from the inside with windows down. But once i put my foot down on the clutch the sound goes away help me out guys
Old Apr 27, 2009 | 11:05 AM
Majofo's Avatar
bearing.. PM SouthernBoy
Old Apr 27, 2009 | 07:18 PM
TL|GTX's Avatar
A Black TL
Its an actual birddy
Old Apr 28, 2009 | 12:02 AM
BukvaMan's Avatar
i have the same problem... took it in once and they did the TSB per my request but that did not help. When i listen to mine i hear it the most at the right front wheel well. It sounds like water bubbling. Its doesn't seem good.
i gotta have it fixed before i put on my new ATLP exhaust.
Old Apr 28, 2009 | 12:39 AM
SpecTro's Avatar
Hmm, i have the same sound but i can only hear it from the inside, coming from the passenger footwell. It sounds exactly likw water boiling too.
Old Apr 28, 2009 | 12:56 AM
salu8819's Avatar
"Let's Do This"
Mine sounds like a bird LOL WTF
Old Apr 28, 2009 | 01:02 AM
NAiL05's Avatar
Could be a throwout bearing on its way out as someone mentioned already.
Old Apr 28, 2009 | 03:46 AM
soichiroUA6's Avatar
4th Gear
I work at Acura and there is a TSB for 05-07 TL for the symptom you are mentioning. It is for a complaint of a chirping sound from the timing belt side. The fix is a new t-belt, shim for idler pulley, grinding of mount in front of idler pulley and new crank gear
Old Apr 28, 2009 | 07:31 AM
salu8819's Avatar
"Let's Do This"
Thank you^^
Old Apr 28, 2009 | 09:05 AM
Majofo's Avatar
that's not relevant to the OP's symptoms. I agree if it's a chirping from the passenger front wheel well that's not associated with the drivebelt then it's definitely the timing belt TSB.. but he says it goes away when he puts pressure on the cluth which indicates a fouled bearing. OP.. PM SouthernBoy or take your TL to a reputable service shop that specializes in Honda's. Or take it to Acura.. They'll say new Tranny.. then take it to a reputable service shop.
Old Apr 28, 2009 | 09:36 AM
4th Gear
^^ I guess I missed that part.. but I've seldom heard that input shaft bearing go on the 3G TL's/UA6's.. it was more common on the old d/b - series honda/acura's
Old Apr 28, 2009 | 09:45 AM
Majofo's Avatar
it's the first I've seen as well on this forum.. mostly clutches and 3rd gear issues.. oh btw.. Welcome to Azine! I didn't notice you were a new member. Glad to have you as part of the group. Best thing to do here is explore the site if you haven't already..
Old Apr 28, 2009 | 05:04 PM
SouthernBoy's Avatar
Registered Member
My initial reaction was the release bearing. A few questions, please.
o What year is the car and are you the original owner?
o Does this happen whether or not the engine is fully warmed up?
o Is it consistent in that if happens all the time and not just occasionally?
o Do you notice any sort of "roughness" when depressing the clutch pedal?
Try this. In a safe area, like your driveway or a parking lot, simulate the conditions where this happens. Then just barely touch the clutch pedal. Does the sound disappear? If not, apply just a little more pressure until it does disappear.
Let us know what you come up with.
Old Apr 28, 2009 | 05:51 PM
salu8819's Avatar
"Let's Do This"
05 TL m/t yes original owner
yes happens even when its warmed up
happens occasionally not all the time
no roughness from clutch
yes the sound disappears when i step on the clutch then it comes back
Old Apr 28, 2009 | 06:09 PM
Registered Member
Ok, so you're the original owner therefore you are the history of and with the car. Did (or do) you ever have a habit of resting your foot on the clutch pedal, even ever so lightly, while driving? Or rest your foot on the pedal while sitting at a light?
As for occasionally happening, does this mean after a long drive in traffic?
Now still try what I suggested to do in my prior post.
Old Apr 28, 2009 | 11:17 PM
D'sNBP's Avatar
hates potatoville
It's your throwout bearing. Mine started to go out at 49,485 miles on it. Take it to the dealership and they will replace it. If you wait it will get worse. No warranty will run you about 1500 bucks. That's what they told me. They also fixed my third gear problem too. Yeah I have an 05 too.
Old Apr 29, 2009 | 05:01 AM
Registered Member
To salu8819;
In case you're not aware, the terms "throwout bearing" and "release bearing" are one and the same.. same component.
Old Apr 29, 2009 | 08:34 AM
salu8819's Avatar
"Let's Do This"
^^^ im a very good stick driver. i nerver rested my foot on the clutch. how the hell does that shit go bad? and my father said it just might be the belt
Old Apr 29, 2009 | 10:37 AM
Registered Member
The two most common reasons for release bearing failure are lack of toeplay and resting one's foot on the pedal. That is why I asked the question. No need to get defensive.
Old Apr 29, 2009 | 10:41 AM
salu8819's Avatar
"Let's Do This"
no bro not getting defensive.. just telling you that i dont rest my foot on the clutch at all.
Old Apr 29, 2009 | 10:56 AM
Registered Member
Ok, that's fine. Remember, I don't kow you from Adam so I am trying to get whatever information I can to help with some sort of diagnosis. From your description, those who suggested the release, or throwout, bearing are most likely correct. This is definitely something you would want to have fixed sooner rather than later.
Let us know how it comes out.
Old Apr 29, 2009 | 10:58 AM
salu8819's Avatar
"Let's Do This"
ok thank you i appreciate it
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
Iain MacLeod
Sep 17, 2015 01:01 PM
Tsov Tom
Sep 6, 2015 07:56 AM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
