Warped From The Dealer?!
Old Jun 23, 2011 | 10:21 AM
TLove It!'s Avatar
Superstressed
Has anyone here ever got brand new rotors that were warped?
A month ago I bought Power Stop Rotors and Pads from Auto Anything, and installed them three days ago. Two days of driving and the front end shakes really bad when braking from over 45mph. This morning I took the car to a Brake shop and they drove the car put it on the lift and told me the front rotors are warped. Any thoughts?
Old Jun 23, 2011 | 10:23 AM
Can IMPROPER bed-in procedure cause warped rotors?
lifetime warranty?
Old Jun 23, 2011 | 10:31 AM
TLove It!'s Avatar
Superstressed
lifetime warranty?
If your asking if I installed them propperly, I am quite sure I did. I sanded the surface that the rotor rests on. Everything was torqued propperly. There is less than 50 miles on the brakes.
Old Jun 23, 2011 | 10:32 AM
I'm asking if you bed them in properly.
Old Jun 23, 2011 | 10:45 AM
TLove It!'s Avatar
Superstressed
I have no idea what that means. Any time I have ever done brakes, the same process was used. Install them properly and drive with no problems. So call me DUMB but what is bedding them mean?
Old Jun 23, 2011 | 10:46 AM
you're not dumb.
Old Jun 23, 2011 | 10:50 AM
TLove It!'s Avatar
Superstressed
you're not dumb.
OK, but can you explain bedding brakes before I search?
Old Jun 23, 2011 | 11:14 AM
TLove It!'s Avatar
Superstressed
I always do step one and two, but always just called it breaking them in. I don't think not doing this would warp the rotors though.
http://www.zeckhausen.com/bedding_in_brakes.htm
Old Jun 23, 2011 | 02:18 PM
Turbonut's Avatar
This is from the PowewrStop site:
Brake Pad Break-In Procedure
IMPORTANT: BREAK IN NEW BRAKE PADS/ROTORS USING THE PAD BEDDING PROCEDURE AS FOLLOWS. PROPER PAD BEDDING CAN PREVENT ROTOR WARPING.
The break in procedure is critical to brake performance. The reason for a proper break in is to establish an even layer of friction material deposited on the rotors from the brake pads. It is very important that this initial layer of friction material is evenly distributed. Break in the pads as follows: 5 moderate to aggressive stops from 40 mph down to 10 mph in rapid succession without letting the brakes cool and do not come to a complete stop. Then do 5 moderate stops from 35 mph to 5 mph in rapid succession without letting the brakes cool. You should expect to smell some resin as the brakes get hot. After this is complete, drive around for as long as possible without excessively heating the brakes and without coming to a complete stop (Try for about 5 minutes at moderate speed). This is the cooling stage. It allows the heated resin in the brake pads to cool and cure. After the brakes have cooled to standard operating temperature, you may use the brakes normally.
Chances are your rotors are not warped, but the pad material has a buildup in various spots on the rotors and this is creating the pulsation.
08KBP_VA
Oct 22, 2019 01:55 PM
Euro4gen
Dec 12, 2015 03:14 AM
dainmezron
Oct 16, 2015 06:56 PM
Avenger411
Oct 11, 2015 03:53 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
