vTEC housing/solenoid leak
7th Gear
took my car to dealership says i have a vtec housing leak..
could someone give me a link or idea of how to fix ive never taking that apart dont want to get in to something i dont need too
Here:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
#12 is the VTEC solenoid, #13, 26 & 11 are the seals.
Easy to do with an oil change it's only 3 bolts, careful with the connector on the VTEC solenoid when I replaced #11 the wire on the solenoid came out of the connector and I had to fix it afterwards.
Leak there should be pretty easy to see if you remove the passenger wheel and pull back the plastic liner to expose the filter and the spool assembly. My guess is it's probably #11.
IBankMouse
06-13-2020 12:53 PM
