VSA triangle Light flashes
So the other day I'm driving my 2005 TL, and it went into limp mode. Then the VSA flashed and it would not accelerate. RPMs was high. So I pulled of to the side and the car was stuck in DRIVE. I turned off the ignition and then was able to start it back up and put it in park. So I called and had it towed to shop who said the tranny was gone. I asked did they the codes and they said no. They then offered to rebuild my tranny for $3600, I said wow! So I went and picked it up and ran the codes.
P0420 catalyst efficiency below threshold bank 1
P0128 coolant temp below thermostat regulating temp
P0125 closed loop fuel control efficiency coolant temp
P0721output speed sensor CKT Rng / performance
I need help bad. I did recently put in a radiator and didn't clear codes. The dealer where I got the car a year ago replaced the catalytic converter.I did drive it from the repair shop with the VSA turned off.
mada51589
05-03-2022 08:54 PM
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
HeloDown
09-08-2015 06:51 PM
