VSA and triangle indicators are on
Old Apr 6, 2020 | 03:52 PM
firebolt's Avatar
Hi!
As I understand it is a well known problem. When I start engine, the "/!" indicator is on, when I drive faster then 30 MPH, the "VSA" indicator turns on too.
I don't know what caused this problem. First time when it happened it was during playing games with OBD scanner. I read all error codes of engine, ABS, something else. And when OBD scanner was connected I took a short drive and these lights turned on. But before that my battery became out of charge and I couldn't start my engine. I charged the battery and took a long drive. No error lights was turned on. After that trip I removed all my wheels to check my brakes and pads. And the next day I was playing with OBD scanner and got this problem.
Now I found one video about Acura MDX 2003 how to turn these lights off without dealer scanner. And I want to ask whether this method works on TL too.
He says to clean error codes first. Error #84-1
Then he says to do:
-Insert both ends of a one wire into pin 9 and 4 of the OBD port.
-Turn the ignition on
-After the ABS lights turns off, quickly press the VSA off button
-After the ABS lights turns on again, quickly press the VSA off button again
-Triangle /!\ light will blink
-All lights ABS, VSA & /!\ should turn off.
Problem solved
Video is
Old Apr 7, 2020 | 02:44 PM
https://www.google.com/search?q=vsa+...hrome&ie=UTF-8
it's a common issue on the 3G if you do a search, you'll see that the root cause is typically the VSA switch
There's also this thread here:
https://acurazine.com/forums/3g-tl-p...-light-912479/
Old Apr 7, 2020 | 03:39 PM
firebolt's Avatar
Thank you for your reply. Actually at this moment I am looking for the way to clear error codes. If it will come again I will search the root cause. Thanks for sharing your experience about VSA switch. I will check it with my multimeter.
Old Apr 9, 2020 | 12:10 AM
HVAC34's Avatar
Originally Posted by firebolt
Hi!
Then he says to do:
Problem solved
Video is here
you say you removed the wheels and were poking around in the brakes? Coulda knocked an abs sensor loose. They’re brittle with the age of our cars. I accidentally broke one when doing a brake job. It wasn’t even part of the job I just leaned on it kinda weird n it snapped
Old Apr 9, 2020 | 12:29 AM
firebolt's Avatar
Yes! Thank you! I had this idea too. But yesterday I was viewing photos on my phone and saw that I removed the wheels only next day, after my games with scanner.
ouachita
1/2G MDX (2001-2013)
Nov 25, 2015 09:48 AM
franco838
Oct 25, 2011 12:40 PM
GD196
Aug 1, 2007 01:46 PM
wilsel
Feb 26, 2006 02:43 PM
Yui
1G TSX Problems & Fixes
Sep 21, 2003 08:07 PM
