Vibrations on cold start
That's the ECU compensating for the lack of heat in the motor thereby causing a rough idle until the car warms up a little. It just runs the motor lean during the startup.
Once the rough idle ends its typically fine for you to drive away slowly until the transmission and engine fluids achieve operating temperature.
d1sturb3d119 (11-18-2013)
I get some small vibrations when the car is warming up in the morning as well. I just let it warm up for 2 - 3 minutes and it's back to normal. I've always let my vehicles warm up for a few minutes in the winter months before driving them.. just a habit of nature for me.
Vibrations won't change if any of your mounts have a problem. You would feel it consistently.
Plus your car is a couple months old. There's no way you would have broken a motor mount this fast.
Check on it if you like, its always good know where all these parts are and keeping a look out for them. After all the miles I've put on the original motor mounts I'm impressed nothing's come apart so far.
So I doubt you would have a broken one right now given the fact that its smooth once it heats up.
rockyboy
08-04-2024 10:35 AM
