Vibration when braking - not rotors
So I have a vibration when braking from 55 mph or higher. It seems as if the whole front end vibrates. Felt some of it in the petal so put on new pads and rotors. That did not fix the problem. I rotated my tires and that also did not fix it. There is also a slight jerk in feeling in the car when coming to a complete stop? Where should I look next?
The DVD-A Script Guy
Still coming through the steering wheel? Did you check the rear brakes? Your post wasn't clear about if you did front brakes only. MT or AT and what parts did you use (OE, etc...) Could be suspension but let's rule out the rear first since you could get some vib from those too when braking at those speeds.
yes i am feeling the vibration in the steering wheel/front end. i'll try to measure runout on the rear rotors....
still coming through the steering wheel? Did you check the rear brakes? Your post wasn't clear about if you did front brakes only. Mt or at and what parts did you use (oe, etc...) could be suspension but let's rule out the rear first since you could get some vib from those too when braking at those speeds.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
