Vibration starting at 60 mph
Old Oct 5, 2011 | 11:55 AM
franco838's Avatar
Hey guys,
I have a 2005 Acura Tl. As soon as I reach about 60 mph the whole car starts vibrating pretty bad. i recently did the following maintenance on my car.
1. Rotated the tires
2. Replaced rear rotors and brake pads
3. Replaced front brake pads only
4. Had to replace right rear studs that were striped from the idiots at PEP BOYS!
All the help would be greatly Appreciated! Also the car did not vibrate like this before this was all done.
Old Oct 5, 2011 | 11:57 AM
franco838's Avatar
I also put slime in right rear tire to patch a slow leak. Not the aersol can version. This type of slime is guarantee in the tire for two years.
Old Oct 5, 2011 | 11:58 AM
jokerman826's Avatar
Jokerman
are you able to tell where the vibes are coming from?
Old Oct 5, 2011 | 11:59 AM
Jokerman
you need to unmount that tire and get that crap out of there, that stuff is only for temporary fixes and car damage your wheel.
Old Oct 5, 2011 | 12:13 PM
franco838's Avatar
there were two different versions of the slime. One was for temp fix and the other was perm. i grabbed the perm version.
Old Oct 5, 2011 | 02:17 PM
justen's Avatar
I have the same issue, I think it might be tranny related since it only does it when im accelerating. harder i accelerate, the worse it shakes, and i can coast down a hill at 60 and its fine. I just ordered some redline racing ATF to see if that makes a difference. i'll let you know
Old Oct 5, 2011 | 10:52 PM
05AV6's Avatar
sounds like Axles or wheel balancing issue,i would check both!
mada51589
Jan 9, 2025 04:40 PM
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
obert
Dec 14, 2015 11:36 PM
PortlandRL
Sep 14, 2015 12:01 PM
