Vibration at the gas pedal
Hello,
I hope someone can help me with this problem that im experiencing with my 2007 acura tl type s. When i excellerate from 60-80mph, my whole front end of my car vibrates along with the gas pedal. I dont know what this could be related to. I just balanced my tires. Please help!
how low are you and how many miles before lowering? sounds like an axle/cv joint
Radical Member
Weird that the gas pedal would vibrate, being that it isn't connected to the engine. My car does the same thing at times, but not at those speeds.
jvieira21 (03-18-2013)
ok so I just had a mechanic look at my axles/ cv joints and he has said that everything looks good and no sign of wear and tear... he was suggesting rotors or thread on tires. idk
Tire balancing won't cure your issue. And idk what kind of mechanic wouldn't know how to diagnose a bad cv axle. You can't visually see if it's bad when it's an axle vibration. You can only swap out known good ones and test drive it to see if it got better. Considering you said yourself it only shakes on accel then goes away as soon as you let go of the throttle, I am confident, 100% it's an axle. And if you in New England and willing to drive, I will swap them out for you, at a fair cost. $60 per axle.
jvieira21 (03-19-2013)
im having the same problem the car vibrated when driving and when i start braking also. i already replaced rotors, brakes, struts (im dropped btw), sway bar links, compliance bushings, got new tires (balanced) and an alighment
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
