V-LED DRL Fix........ wtf happened?
so i ordered some of the newly released vled drl fix for the drls... the ones that suppose to fix the drl light on the cluster and give enough power to light up the DRLs....
so i plugged one module on the passeger drl... im running 55w hid for the drl... and the driver side turns on but the passenger stays out... within 30sec the module starts to smoke and the driver side turns off... so it burned out within a matter of seconds.
i plug another module in thinking it was a fluke, and the same exact thing happened. the module burned out... im out $$ and my DRLs still do not work...
anybody know what happened??? i installed 55w 5000k hid in place of the DRLs and i ordered the VLEDs modules in hopes of fixing the problem, but nothing
this is what it says directly on the v-leds website, read the part in red:
Having issues with your LED or HID conversion on a vehicle with Daytime Running Lights? This is your solution! The easy plug n' play in-line module from V-LEDS. These will provide full power to LED bulbs or HID relay wiring when installing in a low voltage DRL system. Works with all vehicles using 9006 bulb for DRL or when converting to HID using a relay harness.
Not for use with standard bulbs or direct connection to HID ballast.
Measures: 35x35x20 mm
Input Voltage: 3V-14.5V,
Output: 14.5V/500mA
Max Current Draw: 7.2W
looks like you drew too much current through the module and smoked it by using a 55 watt HID instead of an LED bulb like what the module is designed for.
Output: 14.5V/500mA
SidhuSaaB
May 30, 2020 12:40 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
