using non-honda engine coolant?
Old Mar 18, 2009 | 09:44 AM
Sweet07TL-S's Avatar
Question using non-honda engine coolant?
Is it ok to use non-honda engine coolant? Owners manual says to do so temporarily until you can get the cooling system flushed and refilled with honda coolant. It does say to use 50/50 mix. I noticed that my TL-S is way below the minimum level. I'm going out of town this weekend and want to get it taken care of so I can take me Tl. Autozone has a couple of different kinds of 50/50 mix. Prestone is the one I would choose.
Old Mar 18, 2009 | 09:57 AM
andrew070489's Avatar
^ i use prestone and have no problems. Its like oil mobil 1 or valvoline, same stuff different name for the most part.
Old Mar 18, 2009 | 10:15 AM
Spiritman's Avatar
Man of God.....
Cool
I used AMSOIL coolant. It's new from them. Work great! Also water wetter from Red-line. He is rock solid no matter what the temp is. Even in stop and go traffic!!!
Old Mar 18, 2009 | 03:11 PM
I'll probably pick up the prestone. I figured it was just a sales tactic to make sure that I would have to buy from Honda/Acura.
Old Mar 22, 2009 | 08:05 AM
05GRYTL's Avatar
If its only the reserve tank that is low on coolant you can leave it alone and be fine. If the radiator is full to the top then don't worry about it until you can get the Honda coolant.
you do NOT want to MIX prestone and the Honda coolant. Don't! I have seen water pumps ruined by mean green in Hondas. There are major differences between the blue coolant that Honda uses and that green stuff.
If anything, add a little water or something. Don't mix the stuff.
It's always good to buy a bottle of each fluid your car uses to keep at home, you never know when you'll need it.
Old Mar 22, 2009 | 09:41 PM
I hate cars's Avatar
Agreed. Don't mix. If it's just the overflow, buy a gallon of distilled water for $1.00.
SidhuSaaB
May 30, 2020 12:40 AM
01CLOwner
Oct 9, 2015 01:07 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
ghuns
Sep 16, 2015 04:26 PM
