Upper trans mount DIY please?
Old Dec 20, 2012 | 09:24 AM
4drviper's Avatar
the square rubber piece with 4 arms ( you can see when you remove intake box), one of the 4 arms is broke on mine.
I didn't find any instructions here so i searched accord forum, ody forum, guessing they pretty much have the same trans mount (engine too)
but i didn't find anything with pics or service manual scan.
anyone know where i can find these?
or is it sooo easy that nobody bothered to post?
Old Dec 21, 2012 | 01:31 AM
djdonte's Avatar
That same thing happened to mine... dealer fixed it under warranty tho. It looks pretty straight forward all the bolts are accessible. Just make sure to support the engine/tranny with a jack and block of wood.
Old Dec 21, 2012 | 02:08 AM
paperboy42190's Avatar
I did it myself....not too bad
Old Dec 21, 2012 | 03:21 AM
4drviper's Avatar
^ how did you access the 3 bolts in triangle formation? from the bottom?
Old Dec 22, 2012 | 04:59 PM
the hardest part was removing the battery tray, that one had a bolt way bottom hard to reach I had to use extensions and universal joints. then the 3 bolts for the mount was pretty straightforward, takes a bit of reaching, but every bolt is done from on top of the engine bay, helps to have smaller hands
Old Dec 25, 2012 | 12:55 PM
redoctoberz's Avatar
When I did mine I used box end wrenches to get to those bolts, took a while since it is tight, but it is possible.
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
08KBP_VA
Oct 22, 2019 01:55 PM
adreano17
Sep 29, 2015 08:48 AM
Brandle34
Sep 23, 2015 07:20 PM
