Upper trans mount DIY please?
the square rubber piece with 4 arms ( you can see when you remove intake box), one of the 4 arms is broke on mine.
I didn't find any instructions here so i searched accord forum, ody forum, guessing they pretty much have the same trans mount (engine too)
but i didn't find anything with pics or service manual scan.
anyone know where i can find these?
or is it sooo easy that nobody bothered to post?
That same thing happened to mine... dealer fixed it under warranty tho. It looks pretty straight forward all the bolts are accessible. Just make sure to support the engine/tranny with a jack and block of wood.
^ how did you access the 3 bolts in triangle formation? from the bottom?
the hardest part was removing the battery tray, that one had a bolt way bottom hard to reach I had to use extensions and universal joints. then the 3 bolts for the mount was pretty straightforward, takes a bit of reaching, but every bolt is done from on top of the engine bay, helps to have smaller hands
adreano17
09-29-2015 08:48 AM
