Upgate:a/c leaking water on passenger floor
Chapter Leader (Central New Jersey)
turns out the dealer said the line was clogged..and this problem fried my pcm...so they had one shipped over night...service manager said that when acura designed the route for the drain line for the a/c it has some flaws...so they gave it a more direct route to prevent this from happening again...
im not quite sure what they did to reroute it...but i hope this works out for me....i see alot of people having this prob...ill inquire about it from the service manager and see if he can explain
he said instead of it turning and wrapping around that hump off to the passenger side of the car....they basically ran it straight down through the hump....drilling a hole and using a rubber gromit to prevent road water from getting in...and also to keep the sharp edges from cutting the drain line hose...so far it is working like a charm
SidhuSaaB
May 30, 2020 12:40 AM
Sep 17, 2015 09:01 PM
