Uh OHH HELP !
Old Jun 14, 2009 | 11:17 AM
Gary TL S's Avatar
JDM ... NOT !
Exclamation Uh OHH HELP !
Ok so I dont know what happened, How it happened, Why it happened, but im hoping somebody here knows. Today I closed my driver side door and locked it and now when I try to unlock it the driver side wont unlock nor will it open. Seems like it is stuck or something like it wont unlock or open at all. All other doors are fine.. Any body want to pitch in there 2 cents towards a solution ?
Old Jun 14, 2009 | 11:30 AM
mmp1214's Avatar
2008 tl-s sleeping in
thats so weird, did you play with the settings or something?
Old Jun 14, 2009 | 11:31 AM
Gary TL S's Avatar
JDM ... NOT !
dude i didnt do nothing !!
Old Jun 14, 2009 | 11:52 AM
mmp1214's Avatar
wow that is really strange so are you getting in and out through the passenger side door? My friend with a TSX had a similar problem his car alarm went crazy, and locked him out of his car he had it towed to the dealer and got it fixed there. I think that's your best option.
Old Jun 14, 2009 | 12:14 PM
RonJonTL757's Avatar
Former Whyner
that sucks never hear but it sounds like the door actuator lost power maybe
Ever watched Dukes of Hazard
Old Jun 14, 2009 | 12:51 PM
Gary TL S's Avatar
JDM ... NOT !
Lol yes I jump over through the passenger door, I m too big to fit through the window or sunroof so that wont work.
Old Jul 26, 2009 | 04:22 PM
bcbtony's Avatar
07 WDP TL
i had same problem open the door panel and the wire you see that open the door is probably loose check it and if it is the just fix it simple if you need help pm me
Old Jul 26, 2009 | 05:49 PM
thait's Avatar
I need a car in
door actuator?
Old Jul 26, 2009 | 08:33 PM
Tripnbeats's Avatar
there are rods running on the inside of the door opening n closing hinges for the door and also a wire telling the multiplex that the key opening the door is the correct key...one of the rods or some of the rods fell off can u open it from the inside of the car?? you may have a broken lock clasp..i know on mine if i try to open the door before i unlock it i have to put the window down pull the handle on the outside and then unlock it because the part went to shit...its under warranty but just dont have time to get it done. a wire may be loose....have u had any kind of service done at any point that required the door panels or fuses to be pulled?
Old Jul 27, 2009 | 10:06 AM
Majofo's Avatar
Gary's car is falling apart..
Check into what Trip & Tony suggested..
Old Jul 27, 2009 | 12:49 PM
1fsthatch's Avatar
weird..and you dont have warranty right even tho your mods should have nothing to do with the door or anything interior wise
Old Jul 27, 2009 | 06:38 PM
RACINGHART03's Avatar
Does it lock and unlock with the key?
Old Jul 27, 2009 | 09:09 PM
Tolik's Avatar
weird
guess you will have to drive without any doors
Old Jul 28, 2009 | 07:25 PM
msr1011's Avatar
I am also having the same problem with my 05 TL. I googled the problem and learned from other websites, including this one, it could probably be a faulty door lock actuator.
I am getting mine fixed next week and will let you know how it went.
Old Aug 1, 2009 | 04:02 PM
grondie's Avatar
I'd just take it to the dealer and let them figure it out.
GunnmeTaLCURA04
Home & Garden
May 9, 2006 04:34 PM
