turn trunk light off
Old Jul 13, 2008 | 08:59 PM
phatbastard's Avatar
Is there a way to turn the trunk light off while the trunk is open? I spilled gas in my trunk the other day and i need to let it air out. But the trunk light stays on...
Old Jul 13, 2008 | 09:06 PM
LoveMyTL-S's Avatar
You can pull the bulb, or take out the lighting fuse, or disconnect your battery. I'd pull the fuse. If you disconnect the battery you'll have to reset your radio and Navi.
Old Jul 13, 2008 | 09:10 PM
Old Jul 13, 2008 | 09:40 PM
ifirahse's Avatar
SlammedOnKonis
I'd take out the bulb. It's pretty simple to remove.
Old Jul 13, 2008 | 09:53 PM
ricgrrarrow's Avatar
Stuck in Vegas.
yeah, pull the bulb/fuse .. and don't spill gas in the trunk, that's the best idea
Old Jul 14, 2008 | 07:34 AM
LoveMyTL-S's Avatar
Can ya say "All weather trunk tray"? They are a trunk saver.......
Old Jul 14, 2008 | 08:48 AM
I let it air out last night, i do not smell any fumes. I also took a wet towel and tried to soak up as much as possible last night.
Old Jul 14, 2008 | 08:53 AM
AcuraTLG3's Avatar
bulb/fuse...and then get a trunk tray, had a liter of rootbeer leak in the trunk after a party the other night...just pulled out the tray, hosed it off, let it dry in the sun and put it back...all while remarking how beautifully clean my trunk carpeting was
Old Jul 14, 2008 | 09:54 AM
1995hoo's Avatar
Keep Right Except to Pass
Acura has never provided a way to turn off the trunk light. I always pulled the fuse for the trunk light in my old 1986 Legend whenever I was tailgating before a game or a concert. Worked fine, and as others note it protects your security codes (not an issue in the '86 Legend!). Just make sure you put the fuse in a safe place, as those things can be easy to misplace. I always used to put mine in the shift boot under the theory that since the car was parked that was a good safe place, and also if I forgot that the fuse was pulled I'd see it there after the concert or game.
I concur with the other folks on the trunk tray. I got one when I bought my TL and have always been thankful for it, although I do have to admit there may be something to the argument some folks make that says "why are you keeping your car pristine for the next owner, given that you will never see the trunk's carpeting?"
Old Jul 14, 2008 | 12:46 PM
SporkLover's Avatar
B16 Swapped TL
are the dead bodies in your trunk complaining about not being able to sleep with the lights on?
mada51589
Jan 9, 2025 04:40 PM
handsom-hustla
Nov 13, 2015 05:04 PM
pozebly
Sep 23, 2015 07:30 AM
PortlandRL
Sep 14, 2015 12:01 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
