Trunk release doesn't work?
Old Mar 29, 2012 | 01:06 PM
Mrtastygoody's Avatar
Level: Noob
My trunk button don't work. The key one does, but the actual button under the steering wheel does not do aaaaaaanything. Anyone have any suggestions?
Old Mar 29, 2012 | 01:24 PM
legendbliss's Avatar
Check the trunk lock switch in the glove compartment.
Old Mar 29, 2012 | 01:42 PM
A SiQ TL's Avatar
Old Mar 29, 2012 | 02:16 PM
TL Rome's Avatar
8th Gear
^^ yea chances are you accidentally pressed
Old Mar 29, 2012 | 03:55 PM
AcuraIntegTL's Avatar
keep it clean
If it's not the switch in the glove box, check the fuse. Last, you may have a bad switch like I did. If that's the case, it's plug and play for the replacement part. Also, there are a few threads on this topic.
Old Mar 30, 2012 | 11:30 AM
dontTL'em'nothing's Avatar
riding low and steady
have you taken the lower dash panel off (panel under the steering wheel). may have broken the switch itself.
Old Mar 30, 2012 | 09:46 PM
Cbronze_06TL's Avatar
click up the switch inside the glove box...should do it.!
Old Apr 19, 2012 | 08:25 PM
07landrewtl's Avatar
I had the same problem with my 07 TL. Just checked the switch in the glove box and problem solved! Many thanks!!!
Old Apr 20, 2012 | 11:15 AM
Turbocoop's Avatar
yep, I didnt even know the switch in the glove box was there for a few weeks once, I thought my damn switch was broken... tard
AndrewS
19
Mar 14, 2024 06:59 PM
Ol'Dave
Sep 5, 2020 02:56 PM
TLDude876
Dec 28, 2016 03:18 PM
acurajj
Sep 19, 2015 03:47 PM
PortlandRL
Sep 14, 2015 12:01 PM
