Trunk lid button not working?
Old Oct 10, 2021 | 11:59 AM
Type-R's Avatar
3rd Gear
I have an 06 TL and recently the lid decided to not open so I have to open it manually through the rear seat access. Anyone know the fuse to replace to fix the issue? I am trying to find it but no such luck.
Old Oct 10, 2021 | 12:07 PM
peter6's Avatar
If you can't open it with both button and remote control, chances are that either solenoid failed or there is a break in the wire.
Anyway check those fuses from the diagram:
Especially the under-dash #8.
Otherwise take the trim off the trunk lid, get to the connector for the solenoid and, using test light, check if solenoid receives power then you try to open trunk with remote (or have somebody press the button).
Old Oct 11, 2021 | 01:27 PM
Type-R's Avatar
3rd Gear
Alright I replaced the fuse and flipped the main switch inside the glove box and all is good it’s fixed! Thanks! But what’s weird is the old fuse still had power but the replacing it fixed it still.
Project X
Aug 14, 2019 03:35 PM
02 TL
Mar 25, 2012 05:57 PM
acura2009
4G TL Problems & Fixes
20
Mar 20, 2009 03:55 PM
salu8819
Mar 9, 2009 07:34 PM
blaketag
Dec 24, 2003 06:33 PM
