Trunk Latch Problem
Trunk Latch Problem
So this is an odd, minor problem. Recently the plastic piece that covers the trunk latch fell off. The trunk was still closing fine without it so I left the piece in the trunk and I was like whatever I will deal with it later. So later comes, I look at it, it pops right back on. I'm like ok, that was easy....I go to close the trunk and it doesnt close. I have to slam the trunk to get it to close. Opened the trunk back up and looked at the piece. It looks fine, it can only go on one way. So I took it back off, which was a lot harder than getting it on I have no idea how it came off by itself, and the trunk works great again. Anyone else have problems with this stupid plastic piece?
Been awhile since I posted this. Anyways I had the dealer look at it when I was in for a service some time back and they were no help. They just put the plastic cover back on and said it works fine. Even though it didn't work fine. I took it back off again and have left it off ever since.
that plastic latch snapped off of my trunk and the metal and spring is exposed. my trunk closes fine now but it is not lined up with the rest of the body. if i get a new plastic latch, will every thing line up?
The little spring recently came off in my car, and the trunk is not closing as easy as it did before. It seems as though the only way I can put it back on is to remove the plastic cover but I am having a hard time getting it off. Do I need to remove the gray covering from inside the trunk before I can remove this plastic piece from the trunk latch?
mada51589
05-03-2022 08:54 PM
brandnewcolony
09-12-2015 10:39 AM
