Troubleshooting P0134 Code on 2006 TL
Old 04-01-2013, 05:39 PM
CNC-Wiz's Avatar
Hi all,
We have a 2006 TL with 125k miles, just started showing P0134 code for "No Activity on Bank 1 Sensor 1"
I swapped the bank 1 and bank 2 upstream sensors, cleared the code, after 4 drive cycles got P0154, "No Activity on Bank 2 Sensor 1"
The problem moved with the sensor so I was pretty sure it was the sensor that was originally in Bank 1 causing the problem until I learned that these sensors are not the same.
Now I'm concerned that the new P0154 code may be because I have the wrong sensor in Bank 2.
Any thoughts?
Old 04-21-2013, 08:02 AM
CNC-Wiz's Avatar
Quick follow up post that may help someone else. We swapped the sensors back to their original positions and replaced the bank 1 (rear) sensor with a new one, haven't had any more codes in a couple of weeks.
mAgn8 (07-23-2013)
Old 04-21-2013, 08:29 AM
:what:
Wacker's Avatar
Think about this...if you have the wrong sensor on bank two, then you also have the wrong sensor in bank 1. If there is no code for the other sensor, then I'd say you need a new O2 sensor. The sensors are going to be the same internally. The difference may be in wire length, exra insulation on wire, a retaining clip to hold connector out of the way...etc....something cosmetic.
Old 05-23-2016, 08:32 PM
2007 6SMT Type-S
SurfingScotty's Avatar
Can't get any help on the subject in other threads. You seem to be be the only one with actual I'll ask you, experience on the topic and success.
I have the Bank 1 cylinder 1 /p0134 error message just like you. Can you tell me (or snap a photo) of the sensor's location? I just bought an NGK PN24302 and am hoping this is the right part #.
I'd appreciate it.
Old 05-27-2016, 11:16 PM
2007 6SMT Type-S
Since no one was able to help, I made a little video myself on how to execute the upstream O2 sensor. Enjoy.
Old 07-08-2019, 08:34 PM
hpcacura's Avatar
Thanks! I realize this is 3 years old, but I've got to replace this sensor and this video is just what I needed!
justnspace (07-08-2019)
Old 07-09-2019, 07:05 AM
2007 6SMT Type-S
Awesome! I’m glad I was able to at least one person. 🙂
Jamus22
06-11-2023 10:08 AM
LeVeL
10-18-2015 04:19 PM
MilanoRedDashR
10-02-2015 10:49 AM
thegipper
09-28-2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
Quick Reply: Troubleshooting P0134 Code on 2006 TL
