Transmission on the way out?
Old Sep 10, 2023 | 10:16 PM
World0022's Avatar
Looking for help... 226k 2005 AT. Been noticing a faint high whine that is apparent at all speeds. Car also has not maintained perfect speed -almost feels like it's hitting a headwind now and then (but isn't). Today, while driving about 30 mph, rpm dropped like it was in neutral and green light next to gear indicator turned off. Only lasted a second and then went back to normal. Thoughts?
Old Sep 18, 2023 | 12:22 AM
joe.abp's Avatar
Check your ATF fluid level and condition with engine hot and switched off. Assuming you've been religiously changing the ATF every 30k it should have a red tinge and not smell burnt. The BDGA transmissions are known to eventually burn out the 3rd/4th clutch packs with mileage. Replacing the 3rd/4th pressure switch can allegedly buy you more time, theres plenty of forums about this.
One thing I hope you've done is change out the the ATF-warmer filter on top of the transmission case. I noticed several high mileage TLs in junkyards that had the hardened glue from the filter break apart and restrict flow in the banjo bolt. Take a look into inspecting that as these trannies are sensitive to hydraulic pressure.
Trew
Dec 12, 2012 08:15 PM
Ozzman
Nov 7, 2006 11:11 PM
SilverJ
2G CL Transmission Recall Q & A
Feb 14, 2004 12:42 PM
slats
Dec 22, 2003 08:08 PM
SLVR04TL6PD
Nov 6, 2003 08:04 PM
