Transmission problems
Old Aug 18, 2013 | 09:02 PM
bachimik000's Avatar
Hey I have an 04 acura tl auto and the tranny has been acting funny recently like when im driving it is randomly down shifting sometimes and when I try to put it in triptronic mode it doesnt show what gear it is in. I wanna know the solution could it be that I need to do a tranny flush.
Old Aug 19, 2013 | 01:27 AM
But then sometimes it drives normal. Is there any solutions
Old Aug 19, 2013 | 07:24 AM
Ackack's Avatar
Torque converter needs to be replaced. That is what it sounds like based on your explanation.
Old Aug 19, 2013 | 10:24 AM
How much is the part and is it hard to change. Could it be the torque or can ut be something else
Old Aug 19, 2013 | 10:56 AM
Estaban1's Avatar
"How much is the part and is it hard to change. Could it be the torque or can ut be something else"
Hello Bach,
The torque converter is fairly in expensive. I bought a tranny rebuild kit and torque converter for around $500.
Now, installing it is another matter. The trans needs to come out which requires removing both front wheels, all front suspension, drive axels, struts/shocks, hang the motor, remove all plastic under front, tie rods, front cross member/engine/tranny support. To remove/rebuild the tranny you need a Acura factory shop manual ($140 to $150), a lot of tools and a clean place to work. Otherwise, not too hard. youtube "university" is also a huge help.
Old Aug 19, 2013 | 11:28 AM
What, where ur results afterwords
what if I just change the converter that's it
mada51589
Jan 9, 2025 04:40 PM
pstomps
Feb 20, 2017 03:29 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
