Transmission problem need help
Old Aug 12, 2014 | 03:31 AM
AcuraBoyzPR's Avatar
My transmission runs good shift good but I'm not having the same problem as other people been having the pick up quickly she reverse find she pick up all the gear there no grinding no jerking or slipping what so ever but I keep getting the checking light of the p0741 need some help I still got my thirty day warranty on it and I need this problem fix mind you I took it to the dealership and left it for a week and they said they fix it I drove it two days and then the check engine came back on with the same code and today I took it and they fix it and drove around and said it was fix and when I drove home it was find but I drove it to work it came back on please I need help
Old Aug 12, 2014 | 04:02 AM
YeuEmMaiMai's Avatar
- Low transmission fluid level
- Dirty transmission fluid
- Faulty torque converter clutch solenoid valve
- Torque converter clutch solenoid valve harness or connectors
- Torque converter clutch solenoid valve circuit is open or shorted
- Transmission internal mechanical problem
Old Aug 12, 2014 | 08:11 AM
flyromeo3's Avatar
take it back to the dealer and tell them its not fixed.
If its still under warranty why bother trying to fix it yourself.
mada51589
Jan 9, 2025 04:40 PM
pstomps
Feb 20, 2017 03:29 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
