Transmission problem help needed!
Old Jun 27, 2014 | 12:39 AM
azatabbasov's Avatar
So i own an 2005 acura to with 190k miles. When i accelerate hard or floor it from either a stop or rolling the rpms rev high but the car doesnt gain speed. Its like the clutch isnt engaging with the gears. But when driving in normal speeds and accelerating normal there is no problem. What could cause this? Also i had a blinking D a week ago im not sure if its related or not. And would changing the transmission fluid fix this issue?
Old Jun 27, 2014 | 12:57 AM
Scottwax's Avatar
Mr. Detail
You should start by pulling the code from the blinking D light, that'll tell you where to start.
Old Jun 27, 2014 | 01:29 AM
How do i pull the code from that?
Old Jun 27, 2014 | 01:43 AM
rossv1's Avatar
Your tranny is going out.
Old Jun 27, 2014 | 06:09 AM
YeuEmMaiMai's Avatar
if it is slipping and has a code, most likely you are going to need a new transmission and since the car has 190K on it, I would not even bother as it will cost you a pretty penny.
mada51589
Jan 9, 2025 04:40 PM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
Mike Bertram
Sep 10, 2015 09:27 AM
asahrts
Sep 4, 2015 05:55 PM
quake97
Aug 30, 2015 07:57 PM
