Transmission problem
Old Aug 18, 2014 | 06:26 PM
Sledneck's Avatar
Hi, I have a 2006 TL with the 5AT. Yesterday, the transmission acted of a really weard way. For exemple, it was on the second gear and the engine always varied between 1500 and 2400rpm when I was on a constant speed. In the car, I could feel the shots when the engine was dropping or increasing in rpm. It acted of the same way with the others gears and the green light next to the D was flashing. After some miles, I stop the engine and the transmission seems to be ok since this moment. It is the second time that the transmisson does that. The oil is new and the level is correct. What could be the problem? I hope tje tranny is not going to went out!!!
Also, I think that the transmission is slipping a lot. When I am at 50mph, the engine is at about 1600-1700rpm and if I keep the same speed and I climb a coast, the rpm will increase to 2300-2400rpm but it will stay on the fifth gear. I have to push more on the gas pedal if I want the transmission to downshift to the fourth gear. I deduced that the transmission was slipping. Is that normal or not??
Sorry if I am hard to read, I am French, thanks.
Old Aug 18, 2014 | 10:48 PM
pohljm's Avatar
sounds terminal. get the fault codes read, but sounds like its on its way out
Old Aug 19, 2014 | 10:36 PM
Sledneck's Avatar
Ok I will do that! I called my dealer and they said the same thing than you...
Don't know if a should swap a MT6 or put a new AT5 if it is really the end of my transmission because I am tired to drive an automatic.
Old Aug 20, 2014 | 12:31 AM
YeuEmMaiMai's Avatar
check your 4th gear pressure switch, when my car did that, it was because that switch had failed. replacing it = problem solved and no more p1740 and no more pusling while in drive . if your trans is slipping it may be too late
Old Aug 20, 2014 | 12:51 PM
Sledneck's Avatar
The 3rd and 4th gear switches are new! I replace them when the transmission did that the first time.
Old Aug 20, 2014 | 12:55 PM
do a 6mt swap!
better gearing, lighter and comes with LSD!
Old Aug 20, 2014 | 02:02 PM
Sledneck's Avatar
I would like to, but it will probably be way more expensive than to just change the AT.
Old Aug 20, 2014 | 11:11 PM
yeah so was the one in my rebuilt transmission and as we all know, new products NEVER FAIL...
mada51589
Jan 9, 2025 04:40 PM
pstomps
Feb 20, 2017 03:29 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
