Transmission leaking
Old Oct 28, 2014 | 06:36 PM
quanTL's Avatar
I have an 04 TTL WITH 112000 kms. I'm in Canada. My transmission started leaking about two weeks ago. Took it to my mechanic who narrowed the leak to a gasket. He suggested I take it to a transmission specialist and have them replace the gasket and seal. Which I did at Mr. Transmission. Charge with tax was about 150.00. Didn't notice a leak for a couple days. Then it started leaking again. Went back to Mr. Transmission and dropped the car off for them to check. Was just told there is a crack in the middle of the case and it will cost 600 to pull the tranny out, 500 to put it on a bench and fix it and 300 in parts. The part is a transmission seal kit. I'm not an expert on this so I would like some help from my fellow brothers and sisters here.
Old Oct 28, 2014 | 08:05 PM
Will Y.'s Avatar
Registered but harmless
Sorry to hear. It's not a common problem, but it happens occasionally.
We went through that with our Odyssey (J35)-- 5-speed transmission was fine, but a seal in the middle of the case went bad a couple of years back.
A Honda dealer did the work-- the seal kit was just under $300, but I think the OTD total was $1,300, including replacement of 2 motor mounts that went bad.
Old Nov 1, 2014 | 02:09 AM
YeuEmMaiMai's Avatar
eff that JB weld it and call it a day
Old Nov 8, 2014 | 04:08 PM
quanTL's Avatar
Update: My mechanic took it to another transmission specialist for a second opinion when he heard it will cost that much. They had my car for about a week. Figured it out that it was a pipe on the top portion of the transmission that was leaking the transmission fluid. The fixed it and the cost was 240. Phew...dodged a bullet there. Been monitoring for a week now by placing a cardboard box under the car and no leak!
Old Nov 8, 2014 | 05:22 PM
Slpr04UA6's Avatar
-------Tim-------
^if you have a receipt which states the part/tube that they replaced, that could help some members out in the future! Thanks also for the update!
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
Skirmich
Oct 1, 2015 12:59 PM
steve
Sep 30, 2015 09:23 PM
