Transmission issues starting or normal?
Okay so on the HWY I go WOT on a ramp to the speed limit.
Thing that caught me off guard was it held 4k RPM for at least 3-4seconds after releasing the gas pedal. I clicked it to SS and it was stuck in 3rd gear so I hit it to 4, then to 5 so the RPM would go back to it's normal range.
Thoughts on this guys?
4 seconds is pretty long but definitely didn't cause any damage, do you normally drive hard? The shift logic could have adapted to your driving style and sometimes it'll hold a gear to make sure you have traction whether going uphill or through a turn.. reset it and see if it happens again. It's probably fine.
I would try going 1/2 to 3/4 throttle to get up to speed.. I'm sure it'll pull through all the gears normally. I'm guessing you drove pretty hard after your recent reset? If things don't return to normal or it continues to hold 3rd.. change out the pressure sensors. btw.. your sig says NPB..
mada51589
05-03-2022 08:54 PM
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
HeloDown
09-08-2015 06:51 PM
