Tranny problems AFTER 2nd gear fix recall?
It would be nice to know which transmission you have. I'm assuming a 5at since you mentioned 2nd and not 3rd. If you're talking about the oil jet kit, it helps with the second gear lubrication failures but it does not address the other problems such as. What problems are you having? The lube issue results in the transmission siezing up which usually locks up the front tires when it happens but no other problems.
HeloDown
09-08-2015 06:51 PM
