Tranny Noises and slow shifting
Hey guys,
I have an 08 base TL with about 53k on it.
My transmission is quite loud when shifting into reserve/drive at a dead stop. Also when I shift while driving usually when driving aggressively especially when using the sport automatic shifting it is usually very rough and shifting is quite slow. I have also heard it make an odd noise the best way to describe it is a squeaking noise.
I heard on here a trick about letting off the gas when shifting and that help makes it smoother but shifting is still slow. I know our AT is not exactly the best but should I go ahead and get the 3rd/4th gear pressure switches changed out? I also wanted to change my tranny fluid as it probably has the factory fluid in it. I'm going to be using the honda fluid only because I have an extended warranty and I know it will void my warranty if I use anything else.
I also noticed my car tends to shake a little bit when in 3rd gear on occasion which I assume will be remedied by the pressure switch change out.
I'm not sure if theres an actual problem with my tranny or this is just how the TL is.
SidhuSaaB
05-30-2020 12:40 AM
Pham Alvan
03-16-2016 09:17 AM
joflewbyu2
10-08-2015 11:16 AM
4drviper
09-23-2015 09:00 PM
