TPMS Sensor, Car won't leave Park, car remote doesn't work, car locks on and off...
Out of nowhere, all these problems occured at ONCE.
I was coming out of the gym and saw my car headlights flashing on and off (can't remember if the brakelights were doing the same). I freaked out and ran to the car, but everything seemed fine, but then I noticed my remote wasn't working. I unlocked the car with my key, got in, turned on the ignition.
Car turns on fine, but TPMS System Error message came up (first I ever saw). Would not read any psi from the tire (just "--" for each wheel). That went in and out from normal readings to "--". Car would not leave Park as well, and brake lights were not working.
I was freaking out so I went to grab some food, came back, and the car remote still was not working. I just sat in the car wondering WTF was going on and noticed the car would "unlock" rapidly without even being provoked.
Notes:
On Monday, January 6th, I had my car tires rotated at a Pepboys when I was getting an oil change.
About a 4-6 weeks ago I manually replaced the O-ring on my power steering pump to remove a bad whining sound.
That's about it. If ANYONE can help...
Notes:
The reason why your car will not shift from "park" is the same reason why your brake lights are not working. I would try disconnecting the battery for a few mins and see if that does anything.
Okay update time:
Did shift override and drove it Pep-boys. TPMS and VSA light came on the dash. At Pep-boys, I did a check-engine diagnostic, and the code that came out was P0563.
They did say that my brake-light fuse was the cause of the brake-light issue (and thusly the issue of being unable to shift from Park), so they replaced those. When I received the car, the remote worked fine, the Park and brake issue was fine, the TPMS/VSA issue was fine, and the only problem that remained was the check engine light.
I left the lot and VSA light came on. I stopped for gas, and still the remote seemed to work fine and the Park/brake issue was fine. Made another stop and parked for about 20 minutes, and when I came back out to my car, the SAME PROBLEMS persisted. Flashing lights, faulty locks, TPMS/VSA error messages, unable to brake/shift out of Park.
I went home to research P0563 and found nothing of help except that there were potentially issues with the battery. Went back to Pep-boys to run a test on the battery (not sure if that counts as "disconnecting" the battery) and it checked out fine.
Now, all problems still persist - remote key not working (and I can't manually lock the car), TPMS and VSA lights are on, TPMS System Error, Park/Brake issue.
The guys at Pep-boys suggested I take it to the dealer or an electric specialist. I don't want to go to the dealer because they've misled me before.
If anyone has any past experience or advice, please chime in!
bearingman07936
01-07-2016 03:22 PM
Zonian22
11-14-2015 01:20 PM
andysinnh
09-05-2015 11:38 PM
Zonian22
09-02-2015 08:19 AM
