TL Type S window problem
Hey guys, I have an 08 TL Type-S and for some reason every time I roll down the passenger window it doesn't go back up. I have to toggle the window switch like 20 times for it to go up and it is unpredictable whether it will actually close or not. Anyone else have this problem??
Had the same issue on my 08 TL-S. Turned out to be the door window regulator. Had it repaired for around $300.
You may be able to replace it yourself. Here are some parts from Rockauto.com.
https://www.rockauto.com/en/catalog/...assembly,15596
Or perhaps just go with the window regulator only.
https://www.rockauto.com/en/catalog/...egulator,10217
Hope this helps.
Hope this helps.
before you replace parts use a credit card and towel and clean the window channels on the sides, then lubricate them with some grease and it might solve the issue. Over time channels get dirty and the motor works harder to push up the window.
LoveMyTL-S (05-02-2019)
dubz ASPEC
09-19-2024 04:12 PM
gatrhumpy
06-18-2011 06:10 PM
