TL Type S Fan Running After Engine Shut Off
Good Morning,
I drove my car to work this morning and when I got out, I noticed that the fan was still running. I went to get back in and make sure my heater was off and it wouldn't even crank over and everything reset like the battery died. Here's some factors:
We have been experiencing colder than usual weather up in the North State (Redding, CA); like, freezing. It was snowing last week.
I haven't driven or started the car since Friday, which isn't completely abnormal since we have 3 cars.
I have a coolant and oil leak, but when I park at a certain angle it doesn't leak. We are working on getting it into the shop but we have just been putting water in the reservoir.
I had an issue with the battery shortly after buying the car (Craigslist) when trying to program the AcuraLink system while the car was in accessory mode, about 5 minutes in I tried turning the car on and the battery was dead.
Those are all the main factors I can think of, but I am hoping someone can shed some light on what happened... I am at work now and was going to run out and check to see if the fan was still running..
Thank you in advance..
Update:
i came back out later that morning and the fan was off and car started right up.. My coolant reservoir was completely bone dry so I think the car not starting was it protecting itself. I will still look into the parasitic draw and see if that is an issue but we are definitely trying to get it into the shop ASAP, it’s just the issue of money. Thank you for the info!
Update:
Update:
wusty23jd
21
10-12-2019 09:36 AM
gavriil
02-14-2003 11:43 AM
