TL S 07 - 250 HP - lost 36 HP
Hi, I'm on the forum not long ago, sorry for my English, I use a translator. Not so long ago took measurements of my TL s and the device showed that the car 250 horses
instead of 286. Regulating valves, fuel injectors clean. Who will tell - what could be the problem? ![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
I live in Ukraine, there is no formal service or Acura dealer. Thanks in advance.
![what](https://acurazine.com/forums/images/smilies/what.gif)
Unless you're not measuring a real TL-S.
Cuz, TL 3.2L has 258HP
While TL Type-S 3.5L has 286HP
We measured the two machines at once - Sivic Type R 07 (euro), it showed 201 horse (this is normal) and my car, but I do not have 36 horses. Run my car 35000 miles.
WIN 19UUA76597A005830
ifirahse 250 HP = 212.7 WHP
Registered but harmless
Received 1,106 Likes
Horsepower measurement at the wheels is lower than measurement at the engine crankshaft (used by car makers).
5AT
alexSU Hi
Привет
да и говорю и пишу по русски ну или на Украинском еще можно ))))
LoveMyTL-S
New or old standard - does not matter, I repeat - if the Civic should be 201 horse, and it shows 201, but I have 250 instead of 286 shows. This means that it corresponds to the number of horses instructions, but my quantity no.
alexSU Hi
LoveMyTL-S
Under construction
Izvini Serega, ya nemagu pamoch tebey s vaprosam. Mne ochen trudno pisat pa ruski, a goborit pa ruski ya magu. Ya vapshe s Uzbekhistana, periyehal v 1995 godu cyda. Kak tam nasha Russia, vse patihonku?
(Sorry guys, speaking Russian here lol much easier to communicate with Serega)
Under construction
alexSUYes, in Russia and Ukraine, all is still - money solves everything, laws do not work
. Properly done, that moved![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
(sorry , offtop)
(sorry , offtop)
That's true. If you have money, you are untouchable. I want to visit again, maybe summer 2010.
![Patriot](https://acurazine.com/forums/images/smilies/patriot.gif)
You guys probably surprised, but before the crisis, such a machine we have cost $ 65000 , now $ 45000
alexSU Welcome, but do not forget to immediately buy a ticket back
AZ Community Team
Received 7,770 Likes
Dyno measurements by Drivers here are to the wheels. Acura measures HP at the Crank.
At the crank Acura reports 286 HP; drivers here report ~245HP at the WHEELS. That is normal.
Where are you measuring HP? At the crank or at the wheels? If you are measuring 250 HP at the wheels, that is a little better than normal.
damn.. that sucks.. lol...
Akselerometr.I no doubt in his testimony, we measured the two cars - at one all normal, and I do not If I had all the horses, I would not be lost of stock Camry 3.5, also on a / t. Yesterday I bought a service manual, I will look into the problem
2003 Accord Coupe V6
actually you might still lose to the camry 3.5L. Stock I have seen 14.3@97MPH in the 1/4 mile for the camry. I think the best 1/4 mile I have seen for a stock auto TL-S is 14.5. Its a good drivers race with the edge to the camry due to the 6AT vs the acuras 5AT.
You still haven't answered how you've tested your whp... Если хочеш напиши мне в личку.
The car was originally shipped from U.S.?
AZ Community Team
I'd say it is the test methodology.
How do you test at the crank? When Acura does it, isn't the engine removed from the car (with accessories and exhaust attached)? How else do you access the crank to connect to the dyno?
Even if the above ( ^^ ) is off base, I'd still look at the specific methodology for testing crank HP. Acura uses and SAE standard method (modified a few years ago. 2004? 2005?)
TeknoKing 250 (crank) / 1.175 = 212.7 (whp), if 245 (whp) x 1.175 = 287.7 (crank) .
was originally shipped from U.S in july 2008
я уже устал тут повторять, что можно было бы сомневаться в замерах, если бы мы не померяли две машины. Если в Сивике с завода написано - 201 лошадь, то на замерах он и показал 201-202, а я вместо своих заявленных 286 - получил результат в 250 лошадей. Так какая же разница каким методом проведены замеры, если на одной машине обещанные заводом характеристики совпадают, а на другой (моей) не хватает 36 лошадей. Если можешь сделать понятный перевод одноклубникам, буду признателен, спасибо.
You should check compression and valve clearances, check the timing as well. What type of fuel are you using? What was your a/f ratio?
compression and valve clearances normal. Fuel 98 (our) - 91is your
a/f ratio
I do not understand the interpreter did not translate correctly. sorry.
a/f ratio
spark timing..
air to fuel ratio..
btw.. the TL has reportedly pulled timing on 93 octane.. try using a higher octane, make sure egr valve is clean and adjust pcv valve properly.
air to fuel ratio..
it remains to be tested
98 (octane number of about 95) is the best thing that we have
I can not properly compare with your gasoline, accurate data, I have no
I'd have to agree with the above statements, unless I have sunoco 94octane my car just doesn't feel right. If I put in 91 it feels like it's bogging and misfiring. I suggest getting some better fuel.
InFaMouSLink
10-30-2015 09:43 AM
AcuraKidd
09-25-2015 11:18 PM
