TL making noises
Old Apr 24, 2014 | 07:05 PM
Bach2324's Avatar
TL making noises
So my 2005 TL have noiseswhen it's cold after starting it up right away. When you turn the steering wheel it also makes the noise. After the engine thermometer reach mid-level point, or the engine heats up, the noise goes away. Any idea? I heard it was the o-ring being black instead of orange or whatever but i got that replaced (with a honda O-ring(which was also black but new))...any ideas guys?
Old Apr 25, 2014 | 02:12 AM
Will Y.'s Avatar
Registered but harmless
Search "recall" and "power steering whine" for the long thread on this-- should take about 10 minutes, max, to replace the O-ring with a short 13 mm. combo wrench.
The low-pressure side O-ring should have been replaced as part of the PS hose recall (call the Acura dealer and make sure the recall work was performed, BTW), but sometimes the O-ring isn't changed during the recall since it's on a different hose.
The new/replacement O-ring is orange, and replaces the black one. It costs @ $1 at the dealer parts dept.
If your steering whine doesn't go away in a couple of days, put in a new orange O-ring, unless the recall hasn't been done (let the dealer do the recall work in that case).
Welcome to AZ.
Old Apr 25, 2014 | 05:43 AM
YeuEmMaiMai's Avatar
^ the man has the answer right there...
Feb 25, 2020 09:57 AM
snorf
Nov 4, 2019 06:44 AM
2012wagon
Sep 29, 2015 04:21 PM
real_mckoy
4G TL Problems & Fixes
Sep 25, 2015 10:49 PM
Mike Bertram
Sep 10, 2015 09:27 AM
