This TL has been sitting for 3 years. pls help
hi peeps,
i own a 2006 TL, my ride was short live, when i got one too many speeding tickets, and started to take a toll on my insurance (10K+ at the time). So i stored it in an indoor garage for 3years. as stupid as this may sound, i have not started it since. I am now 23, and finally, the wait is nearly over, i hope if i am fortunate enough to get it started - i will have learned a valuable lesson - and that is IT JUST WAS NOT WORTH IT.
And for the new year i'm hoping to find some decent rates, and get this long lost car on the road. My question is after i get the cover off, what do i need to do to get her back into running conditions.
input is most welcome
regards
Aret
regards
Aret
Check all fluids
Check tires for air & integrity...
Good bet the battery is dead
Once started let it idle & warm up .. check for leaks.
Recheck fluids.
Get it serviced ... oil changes etc.
Recheck fluids.
Remove the plugs and squirt a little ATF in each cylinder, let sit, then drain or suck the old gas from the tank, add fresh fuel, turn the engine over by hand, install the plugs and see if a go. Get a strong battery and after starting, I'd then change the oil/filter and check the brakes carefully as the caliper pistons may have frozen, then on to the brake fluid, coolant, etc.
Off topic but it might have been easier to not speed lol. I had a fast car from the age of 17 and I've never had a speeding ticket.
likely needs a new battery, especially if that one was left connected
If you cant drain the gas tank or it was left low--there is moisture and gelled fuel in there
to fix:
ADD 1 can/16oz seafoam to the tank with 8 gallons fuel/just under half tank.
repeat on next half tank
that will clear out crud and restore things to a baseline of clean
I would change the oil and filter BEFORE starting the engine-
its going to have lots of moisture in it that you dont want to spread around
once its running- flush the brake fluid--thats due every 3 years MAX anyway
easy DIY
good idea to do the ps fluid flush too-- driving it will dry the moisture out, but it has been sitting a long time and bad fluid causes seal problems,,expensive seal problems
to fix:
easy DIY
Hey guys thanks for the helpful replies
Seems like their is lots of fluid work to be done.
Would the dealership be my best bet?
Or just the the ordinary mechanic?
If you're not going to do it yourself, you'll need to have it towed/flatbed to the shop or dealer and you won't know exactly what or how they are going to get it started. If you change the oil before startup, I'd definitely do an oil change afterwards as the metal will be scrapped off the cylinder walls, above and below the rings, and can contaminate the new oil, that's why I would change after startup.
I'm Craig
Interesting choice...
I agree 100% with the notion of having it towed to the dealer. Driving a car that's been sitting for 3 years just doesn't sound like a good idea. Bring another power source for the battery if you do try to start it; I guarantee you it's dead. It was probably dead a month after you stored it. I'm quite sure you'll need new tires also. They're probably rotted to some degree and they most certainly have flat spots if the car has been sitting on concrete for three years. Post pics when you go rescue her though.
hi peeps,
regards
Aret
regards
Aret
Check the air pressure in the tires and get some new ones (tires have a life of about 5 years because of dry-rotting issues.
Believe me, I'm not trying to be argumentative, but here in the US there is no limit on the tire carcass as long as no cracking is evident. On one of our cars we don't use very often, the rear tires are going on 7 years old and no problems, but as mentioned above, if flat spotting is evident, it may take up to 20-30 miles of driving to straighten out depending on the model tire.
B A N N E D
btw OP, i forgot to mention, i know how you feel, with getting your license back and all, i had to ride the bus for like 2 years, cause i could not afford the insurance either
Full of water...
We sold a 1973 coachmen fifth wheel...original tires (tubes?) still on it ....The people that bought it pulled it 150 miles to st paul...lol
There were cracks in the side wall were 1/8 inch.
My father has an '73 Opel GT with some bias ply tires bought in the early '80s from JcPenny. I had to move it the other day and it was kind of scary airing tires up with those kind of cracks.
