Timken or oem wheel bearings ?
I'm about to do my brakes and I decided to do my bearings too.
I know I need them because it make that noise when turning steering wheel both ways
If anyone can help me out I would really appreciate it thanks
No problem with Timken, but what makes you believe it's the wheel bearings, especially when you say that the noise is audible when you turn the steering wheel? Wheel bearings are heard when spinning each wheel or worn excessively when there is play in the bearing itself, indicated by wheel wobble.
If they are that bad as to cause a vibration then you'd be able to feel the play in the wheel bearing and/or hear some abnormal sounds when the assembly is raised and the wheel is spun or rocked back and forth. In a pinch you can raise the front end, put it in gear and see if you can duplicated the noise as you accelerate slightly.
Just trying to make certain you need the bearings before spending the money.
nanos
Nov 12, 2015 08:41 PM
merc009
Oct 3, 2015 12:59 AM
mtl_ilx
Sep 3, 2015 09:48 AM
