Timing marks not even close
So I was doing my TB work, and when I lined up the crank pulley to the mark indicating TDC, the cams weren't even CLOSE. Strange, so I rotated 360*, still not even close. Why would they be so far off, and also, is it possible someone monkeyed with the cam gears in the past and put them back wrong? Orrrr did my TB stretch so bad that this is what I'm left with. Thanks for the help.
-J
-J
OK after pulling the timing cover, it appears the mark is only off by ~15* I can see the belt pull up the slack as I turn it. Should I just pop the belt off, set the cams to TDC to match the crank, and be done with it? When I rotate it 360 more degrees, #1 mark is on the opposite side of the gear, so I'm fairly certain it's just slipping. Thanks.
the overexplainer
The crankshaft turns 2 revolutions for every 1 revolution of the cam. That is why you need to keep rotating the crank to TDC possibly more than once if the cams dont line up to TDC the first time.
It's not a 1:1 ratio.
Before you did anything was the car running fine? Even slipping one tooth should have done something noticeable to how the car ran. The cams and crankshaft are also keyed so they only go on one way.
Unless you took the tensioner off there's no way the belt would slip turning the crank. Can you take and post pictures of the marks you see? How many miles on your car? I doubt someone went through the trouble of sabotaging the cam gears.
the overexplainer
use http://imgur.com/
your belt probably hasnt skipped or stretched then. If it did your car would run terribly all the time.
I DIYed my belt a few months ago and didnt have a problem lining up the marks.
there's also a few different marks on the crank pulley, make sure you're lining up the right one.
OP, you are aware there is a detailed DIY for the TB?
https://acurazine.com/forums/3g-tl-2004-2008-93/122-diy-105k-service-timing-belt-water-pump-spark-plugs-thermostat-%2Apics%2A-784622/
Oh yeah! I been using that one, besides the timing mark snafu which was completely my lack of reading comprehension, the job went well. Borrowing a tq wrench from a friend to tighten the crank pulley this morning and that's all she wrote. It is a great writeup and the pics are solid.
-J
-J
Desert Life Sucks!!
Yeah and 15 deg sounds right for the other mark. Should be a white or blue mark.
That is where your timing is usually at idle. If you had a timing light you would be able to dial it in and check it.
I had to do that when setting idle with eCtune.
5th Gear
Hi guys - changed my own tb and the car now sounds a little funny. Wondering if I might be off by a tooth on rear cam sprocket? How would the car sound if it was off? It seems to run fine and have plenty of good power, but it does have kind of a "throaty" sound. I am digging in, and getting ready to work on a valve judgement, but want to make sure my timing is correct before I start on the valve adjustment. I'll try to get some photos, but I still have the covers on at this point. Any help would be great!
5th Gear
I now have my top timing belt covers off, and everyhing looks lined up to me. The only question I have is how to check the timing marks on the crank pulley with the lower cover on.
I see the black plastic triangle on the timing cover that points down toward the crank pulley. It looks like it is lined up with a small mark on the pulley rim. There are other marks on the pulley rim about an inch to the right. These marks look like three small lines on the pulley rim, and one of them is red. The mark that I am lined up on (over an inch or so to the left) looks either white or yellow in color.
Is there a picture in the forum somewhere that I can refer to? Thanks for your help.....
https://acurazine.com/forums/showthread.php?t=784622
There is also a two-part video from Ericthecarguy.com on the valve adjustment. It's linked in a thread in this Problems forum.
5th Gear
Went and looked again - the three marks are black red black in color. I am not lined up on these marks. The other mark is yellow/white and I am lined up on this one. It is approx. 1/2 inch to the left of the other three marks. Assuming that this yellow/white mark is this right mark, it looks like I am lined up all the way around. I don't think it is possible for me to be off by a tooth.
I am moving on to the valve adjustment. Hope this helps with the noise I am hearing.
5th Gear
If the engine runs and pulls, it's probably fine. Most people say that being just one tooth off would cause severe, noticeable issues. Here's the TB DIY which has pics:
If my valve adjust doesn't help with the noise, I may have to start questioning the timing parts I installed - water pump, idler, etc.
Thanks. I'll look for the video on the valve adjustment. I used the DIY write-up in the above link when I changed the belt, waterpump, etc. It probably helped me to do this job correctly, and it gave me the confidence to do it myself in the first place.
All of my valves were out of spec by only 0.001" (exhaust tight, intake loose) and that seems to be the trend with our J32s at 105K. I couldn't tell a difference after the adjustment (noise, performance, mileage... nada... Which when you think about it is good). I highly recommend acquiring one of those combo valve adjustment tools. They can be found for $20 IIRC and the time they save is worth every penny.
FYI, about 3 days after I did the TB and valve adjustment, I started to hear a faint whine. It turned out that the serpentine belt just needed to be reset on the pulleys. No more whine
I forgot, there is a DIY for the valve adjustment in the Garage (Service Department), but the videos are much better IMO.
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
Hello everyone,
I'm in the middle of a timing belt change (2006 MDX). I just put the new belt on per the written instructions provided with the parts, along with a Chilton's manual.
Initially, I rotated the engine before removing the original belt to just past #1 TDC on the crank; what I saw was that the front cam marks were lining up (there are numerous marks on the sprocket), the rear marks. were a 180 degrees out (one set of marks on sprocket).
Afterwards, I removed the belt, pulleys, water pump, etc. Then everything in reverse order (installation).
Problem I have, is that I have no confidence in the position of the cams in relation to the crankshaft as of now. I don't want to continue the rest of the job just to find out that the timing is off, and then my engine is damaged=(
I checked this link for help: https://acurazine.com/forums/second-...g-belt-695821/
Mike
Mike
Hello everyone,
Mike
Mike
rockyboy
12-06-2022 02:29 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
ahsm
09-09-2015 08:35 AM
