Tighten gas cap problem
Old Jun 19, 2012 | 10:47 AM
hikariz's Avatar
7th Gear
Angry Tighten gas cap problem
My TL s been having this problem for a while now, the tighten screen keep on displaying, i even replace the gas cap and it still going, anyone know what is going on?
Old Jun 19, 2012 | 11:25 AM
alexb92's Avatar
AFAIK there's a software update available from the dealership?
Old Jun 19, 2012 | 06:10 PM
newkatbie's Avatar
Connect an OBD2. read the code. The code for the evap system, small leak, is also triggered by loose gas caps while fueling up. It could be the gas cap, the evap hoses, filler neck, or the canister if the code is the same. If not, it is electrical. Check OBD2 codes first. Go to advanced auto parts, if you have one, and get them to read it for free.
Old Jun 20, 2012 | 01:23 PM
mau108's Avatar
It's most likely the EVAP Canister purge valve. Order the new made in japan part and get it replaced. Should not take more then 15-20 minutes to change.
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
sockr1
Oct 1, 2015 01:31 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
Silverstead1
Sep 17, 2015 06:45 AM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
