"Tighten Gas Cap"
Old 09-20-2009, 07:18 PM
  #41
Chapter Leader (Central New Jersey)
07tl-s6spd's Avatar
ok so apparently there was an update for the pcm...so they downloaded it to mine....and guess what about 2 hrs later the tighten gas cap still came on....i told them i didnt think this was going to work but he assured me that it would....wasmt a surprise to me that it didnt
Old 09-21-2009, 11:52 AM
  #42
mcmanut's Avatar
Sorry to hear it did not work.
Since I replaced the Purge Control Valve, the message has not come back on. It has been a few thousand miles since it was replaced.
Old 09-22-2009, 03:41 PM
  #43
9th Gear
OneTouchMusicGroup's Avatar
im having that problem also its been 2 months
Old 09-22-2009, 04:48 PM
  #44
yjxacurazine's Avatar
Can't believe. My 2009 RDX has only 900miles on it and got this message yesterday after work. The message was gone when I start the car this morning. I'll see if it come back again.
I googled. It happened to so many Acura's (tl,tsx etc.). Why Acura doesn't want to fix this problem.
Old 04-22-2013, 12:58 PM
  #45
VeNoMiZeD's Avatar
So is replacing the purge control valve the solution? I realize this is an old thread but wanted to see if this was the answer now that it's 2013. My 08 TL Type S started doing this about a few months back and now seems to do it twice every gas fill up. Thanks for any reply.
Old 04-22-2013, 03:30 PM
  #46
Acura-OC's Avatar
Did it for me.
Old 04-22-2013, 03:37 PM
  #47
Hacura's Avatar
I have a randomly surging idle I can live with and originally thought the fuel cap error was due to PnP work (vacuum leak). After reading this thread it appears many TL-S's are prone to this issue.
I've reset it for now and if it comes back I'll take to the stealership since it's under extended warranty. They've already said the fuel cap isn't covered under extended warranty.
Old 02-06-2015, 09:33 AM
  #48
2011 SHAWD
Kajan_8's Avatar
Why are you guys just throwing parts in? If your purge valve is having issues you would of got a code for it. best thing I can suggest is if your out of warrenty is to get it smoke tested to see if the evap system has a leak and then monitor the FTP ( fuel tank pressure sensor ). Because that's what tells the computer that you didn't close the cap properly and turns on the light on the dash. I see too many customers that spend money " trying " parts to solve a problem. Been a mechanic too long and seen people replace starters over bad ground. Get it checked people cause you might drive the same car, have the same light doesn't mean it's the same issue.
PS: some dealers don't smoke test because they don't have the equipment. Believe It or not.
Old 02-06-2015, 05:53 PM
  #49
Acura-OC's Avatar
In 99% it is same issue that is why there is a TSB for it.
xsilverhawkx
10-05-2015 11:00 AM
MilanoRedDashR
10-02-2015 10:49 AM
San Yasin
09-29-2015 10:52 AM
jmaxima03
09-27-2015 10:22 AM
Quick Reply: "Tighten Gas Cap"
