Tighten Fuel Cap!!!!!! Help!!!
BANNED
evap canister solenoid valve.
TONS of threads on this. dealer fix, or buy the part yourself and do it.
BANNED
^yeah. diff terminology same thing.
Desert Life Sucks!!
I just replaced mine 25 minutes ago.
PCV valve
https://acurazine.com/forums/3g-tl-problems-fixes-114/tighten-gas-cap-light-3-visits-dealer-already-738498/
part you need and can get an extra 5% off at delray acura. acuraoemparts.com ask for PJ
36162-RDV-J01 Pur Cont Valve
PCV valve
Desert Life Sucks!!
The defective ones are from Mexico, the new ones are from Japan. Took me 5 minutes to swap.
You will need a long needle nose pliers to slide the clamps off and a 10mm socket to remove the valve. You may want to loosen the fuse box to be able to move it out of the way.
Take top vacuum hose off first then remove the nuts/washers and you will have more access to bottom hose.
Swap valves and attach bottom hose first, then nuts/washers and top hose.
I already had all my covers off engine from summer time so it was easy.
I haven't drove car yet but I hear it takes 50 start cycles for the code to be removed permanately???? Not sure on that. I will report back when I get to play with it some more.
7th Gear
Good information. I'm experiencing the same problem with my '06 Acura TL. Some posts elude to manufacturer defect, was there ever a recall?
~ LAcuraBaby
2006 Acura TL Lover
~ LAcuraBaby
2006 Acura TL Lover
joflewbyu2
10-08-2015 11:16 AM
