Tighten fuel cap!
Old Aug 29, 2012 | 07:10 AM
Nesbittaudia4's Avatar
Tighten fuel cap!
08 TL with 80K
So this started around 65K and the tighten fuel cap sensor kept coming on and off. Acura dealer said it didnt pose a real problem so I left it alone on my road trip. Somewhere in Seattle I got new gas cap as suggested as the cheapest fix....that didnt fix it!
So now its just annoying.... anybody else having this issue alot?? Its like every 60 miles or so!
Old Aug 29, 2012 | 06:43 PM
libert69's Avatar
18psi
is it throwing a cel? whats the code number?
Old Aug 29, 2012 | 07:06 PM
No idea, how would one check that. Acura link pops up on the nav with check now or check later.
Next time it pops up, where should i find these codes?
Old Aug 29, 2012 | 09:13 PM
libert69's Avatar
18psi
if you dont have a obd2 scanner then goto autozone or your local auto parts chain and they will check for free.
Old Aug 31, 2012 | 06:32 PM
TIFFANI25's Avatar
I have 68k miles on my 07 TL. I experience this problem off and on as well. I havent had the dealer check it out yet because the light never stays on for long. So by the time I get to the dealer for my service, I usually forget about it.
Having inspection completed at dealer next month, will have it checked out and post an update.
Old Aug 31, 2012 | 10:52 PM
Timstandupguy's Avatar
whats going on this is a common problem there a tsb out for this . the dealer change my purge valve thats the defective part go there and tell them your cap light comes on and there a tsb . done deal
Old Sep 4, 2012 | 10:08 PM
PeterSenzen's Avatar
I have a 07 tl with 70,000km and have had the same issue for the past 10,000km. I put a new gas cap and the issue did not go away. It randomly comes on but does not stay on for more then a few hours. I have not noticed a pattern in mileage or how much gas is in the tank. It is very annoying and have no idea how to resolve the issue.
Old Sep 4, 2012 | 10:42 PM
SenzenTL's Avatar
5th Gear
I also have this issue and replaced the gas cap with no results. Timstandupguy do you have a part number for this purge valve?
Old Sep 5, 2012 | 08:50 PM
36162-RDV-J01 thats the part number When they removed this part from my car this part said made in Mexico i guess that explains the issue. the New part was made in JAPAN THE WAY I LIKE IT. once you change it your problems solved
Old Sep 5, 2012 | 08:58 PM
In Reference to Peter i was having this other issue P0171 bank 1 lean. I ask a Acura tech in the bay working i just wanted to walk back there didnt really care because the service manager didnt know what i was talking about and after getting PGM Update it didn't work they change a map flow sensor it didnt work for the P0171. The acura tec told me it can be many signs for that code to come up and once i heard him say purge valve i know it was the problem because if not sealed right it can release gas vapors. Came back with the TSB and show the Service Rep same day fix its been fix at 57,000 miles now i have 61,455 no issues. Guys switch out that purge valve Japan Materials beats any american or Chinese or mexican quality. Take care
Old Sep 11, 2012 | 09:47 AM
New Car TL-S's Avatar
ok, I got part 36162-RDV-J01, I located it, but that wire harness doesn't want to come off. Trust me, I can get it off, but I will break it...any suggestions tips for a novice to ease the connector off?
Old Sep 11, 2012 | 10:28 AM
gundam07's Avatar
I have the same "Tighten fuel cap"error on my 07 TLS and went to advanceautoparts for a code read. The code returns P0404 which is "Exhaust Gas Recirculation Control Circuit Range". I think it's the EGR and is P0404 code the same on all code reader even on the Acura dealer?
Thanks.
Old Sep 11, 2012 | 05:48 PM
@ Gundam i find that hard to believe, dam that tighten fuel cap is the biggest problem for pretty much at Tl 2007-2008. question have you ever change the Purge valve sensor at all.
Did you try changing your EGR.
@ New Car check the TSB they have the direction on how to install that my friend
Old Sep 12, 2012 | 12:03 PM
I've got the TSB, I just can't get that harness connector off without busting it. Is there a clip holding it I don't see?
Old Sep 21, 2012 | 05:42 PM
citidelx's Avatar
RoadRunner
Tighten Fuel Cap Warning
It cost me $211 to have the Purge Valvbe replaced to resolve this issue. It was really getting on my nerves. Honda/Acura know this is a problem yes refuses to repair their vehicles. I took the part from the dealership. It a cheap piece of plastic that was made in Mexico and was determined to be faulty. So far the warning has not appeared.
Old Sep 22, 2012 | 09:47 AM
@ Citidelx as i mention before its a cheap as part from mexico that was causing this problem. the part was not really hard to put in my friend i believe you could have knock that out one to three. But im glad you Ac has a clean bill of health.
vpasla1
Sep 17, 2016 07:24 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
jmaxima03
Sep 27, 2015 10:22 AM
