Tight steering wheel and it twitches
Old Feb 13, 2011 | 08:26 PM
bacardi_sip's Avatar
04 model, 51k miles on it. The steering wheel twitches on curve and when i apply brakes approaching a stop signal.. Took it to dealer twice and still it is not fixed, the service manager said he drove the vehicle and did not feel anything..I experience even if i drive for a mile.. he drove the vehicle for many miles and said he did not feel anything unusual..
After the vehicle returned from the dealership, i felt the steering little tight.
Should i take it to another dealer and have them check?
Old Feb 13, 2011 | 11:40 PM
csmeance's Avatar
does it twitch while acclerating and braking? The best thing to do is find an on/off ramp and go around 25 with the cruise control set (make sure it's safe to do that speed). See if it twitches. If not, then you are in luck!
This thread:
https://acurazine.com/forums/3g-tl-2004-2008-93/acura-servicenews-bulletins-588838/
November 2010 issue
Page 3
This should fix it. As well have them check and make sure that the recall was performed properly by whoever did the work. Also check your fluid level!
Old Feb 14, 2011 | 09:25 PM
It twitches while braking.. On an uneven road it too twitches unless i hold the steering tight and keep it under control.I tried the test that you suggested did not feel any twitches I am going to try again tomorrow evening and update the results..
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
IIDXholic
Sep 19, 2015 10:18 AM
04tler
Sep 10, 2015 04:03 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
