Threw a code P0658. Car stalled out then wouldn't turn over
Old May 17, 2020 | 07:40 AM
UA6-MT's Avatar
The car is a 2005 tl 6 speed. The check engine light came on then within a minute the car died. Then it wouldn't start. I get help to push it then i pop-start it. It runs. After shutting the car off, I'm able to start it back up and the check engine light is gone.
so what the heck happened? And how to prevent it from happening again. Thanks, y'all.
Old May 17, 2020 | 12:33 PM
pohljm's Avatar
generic low voltage signal to PCM. hows your battery? prolly just a fluke. clear code with a reader and see if it comes back
Old May 19, 2020 | 03:22 AM
UA6-MT's Avatar
My battery is fairly new. Dated 05/19. Rated 550 cca. Car is running well again. It does appear to be a fluke.
Old May 19, 2020 | 08:01 AM
Jackass's Avatar
A fluke? Unlikely. More likely guess would be a problem with your battery cables causing intermittent issues. The TL won't run with the battery not connected. If you cables or clamps are failing, it could have been enough of a disconnect to cause a stall and a CEL. Then a bump or two later, they are all all good again for a while.
I would highly recommend taking a closer look at the positive battery clamp and cable to make sure there is no corrosion and the connections are all solid.
bigg_86
Aug 14, 2011 09:33 PM
itr1197
Jul 31, 2009 12:59 PM
Type-SuperFast
Jan 21, 2009 02:07 PM
bkzjimmy
Oct 11, 2005 09:08 PM
fastsccaguy
Jun 18, 2002 05:11 AM
