For those with squeaking noise from belt area...
Before any one says it, I DID SEARCH! Any way Ive seen many threads about this and would like some general feedback from those with this problem. I took my car to the dealer yesterday so that they can fix this problem,( im am under warranty),when I went to pick up my car they told me they adjusted the tensioner and applied belt dressing and problem solved. WRONG! I drove the car around the block before I went home and the noise was still there. So I left my car there again so that they can look into it further. Mind you, I changed the belt about two weeks ago thinking that the belt was the culprit. My question for you aziners is, did any one with this problem have a similar experience, and if so what was the fix. Thanks in advance.
I have a similar issue and found 2 threads related to it:
https://acurazine.com/forums/3g-tl-problems-fixes-114/problems-belt-tensioner-631119/ and https://acurazine.com/forums/3g-tl-problems-fixes-114/engine-making-noise-600239/ I tried reviving the threads but have gotten no response. My general take is that it is the belt tensioner itself making the noise. I will be making an appointment for my dealer to take a look next week. |
Originally Posted by dwb993
(Post 12133240)
https://acurazine.com/forums/showthread.php?t=631119 and https://acurazine.com/forums/showthread.php?t=600239 I tried reviving the threads but have gotten no response. My general take is that it is the belt tensioner itself making the noise. I will be making an appointment for my dealer to take a look next week. |
Originally Posted by RjG2
(Post 12133133)
OMG...they cant adjust the tensioner since its AUTO ADJUSTABLE. It only mounts one way too Friggin idiots they are. Also, answer my PM, from your previous post https://acurazine.com/forums/3g-tl-problems-fixes-114/weird-noise-engine-bay-776199/ I can more than likely help you narrow it down since I went nuts trying to fix a similar issue. I'm in Queens too btw,...if you place your head by the passenger front tire, does the noise seem louder? |
YES, fly! It is much more audible when I put my head down by the passenger tire.
I called the dealer and they told me they think its the timingbelt tensioner. Long story short, they ordered the part so I still dont have my car.
Fly, I only hear the sound when I accelerate. I cant hear it when its parked and idling. |
(Post 12134191)
It could be loose. Its right aobve where the two exhausts meet at the rear down pipe. heres my previous thread with a picture of the bolt https://acurazine.com/forums/3g-tl-problems-fixes-114/fighting-squealing-noise-778285/ |
tensioner, idle pulley, or tensioner pulley. Replace all three since you have a new belt already.
Originally Posted by flyromeo3
(Post 12135901)
take a look at your heatshield lower bolt.
It could be loose. Its right aobve where the two exhausts meet at the rear down pipe. heres my previous thread with a picture of the bolt https://acurazine.com/forums/showthread.php?t=778285 |
Originally Posted by InFaMouSLink
(Post 12135930)
worst case scenario. the parts cost around $100 and do it yourself!
(Post 12135961)
(Post 12134712)
Fly, I only hear the sound when I accelerate. I cant hear it when its parked and idling. If its the tensioner ( serp belt ) its a simple swap of the pullies. Not as hard to replace yourself. I have an idler and tensioner pulley Ii used for about 50 miles. if you need em. |
(Post 12136029)
Believe me I thought about it, but then I thought why do I have a warranty for.
the warranty is there so someone that doesnt know what they're doing can work on your car for days. I've gotten it down to swapping out the tensioner in about 10minutes. |
(Post 12136117)
(Post 12135949)
I read your thread and I asked the service advisor about that and they looked at me a weird look , If I pick up my car today and the sound is still their I will mention it again. Thanks
there is TSB on the heatshield bolt. which is why I figured to take a quick peek at it. |
(Post 12136377)
(Post 12136377)
Can you post the number of that TSB or a link, please?
(Post 12137092)
(Post 12136377)
your basically going to pay them 85 dollars to tighten a bolt.
extension and swivel head on a 3/8 ratchet is all you need and some of that blue bolt thread stuff. i do hope they replace the whole heat shield though. Which involves removing the down pipe |
(Post 12138330)
UPDATE! I just got my car back a couple of hours ago, and the noise is gone. It was the half shield as recommended by many AZINERS. I was able to get it done for 50 bucks under good will. Thanks to all of you who answered this thread. I hope this thread will help any one else who has this problem.
2005 TL squeak/chirp
I bought a 2005 TL about 18 months ago. It currently has about 45,000 miles on it.
Not long after bringing it home I noticed that the car/engine was a little squeally at low speed. Once I got past 25-30mph the sound disappeared. This appears to be the issue addressed by TSB07-026. Do I call the dealer and ask them to perfom this maintenance? Over the last few months, the enginge started to squeak/chirp. It definitely comes from the passenger side of the engine compartment. The sound is present some days and gone others. The squeak/chirp speeds up and slows down according to how much gas is applied. Does this sound like the tensioner issue others mentioned? Thanks |
It could be either the tensioner or the heat shield. Have the dealer take a look at both.
Thanks, will do. I'm just going to call and see if they will look under warranty first. They told me that the base fee to investigate a problem is $114. Homey would rather not play that (points for reference).
(Post 12337830)
They usually apply it to any fee they charge for service you have them perform.
I have a 2007 TL (24K miles) and upon cranking the car I hear a whistle/ticking noise coming from the engine. It gets louder when I push on the gas. Taken it twice to the dealership and the first time I was told it was the AC Idler...it was replaced. Noise came back. On the next visit I was told it was something with my timing belt and they replaced it and it's components. 2 weeks later...noise is back. This is very frustrating because you would think the dealership would know what this noise is and how to fix it.
(Post 12133804)
Thanks for your input. Im pretty sure that my tensioner has to be replaced. I think the dealer is just trying to avoid having to change it. Im am still waiting to get my car today. I will update this post when I get my car back.
Hi guys, I'm having a similar problem. I have the chirp that goes away at higher RPM's. I found this, what do y'all think?
Originally Posted by SurfingScotty
(Post 15652524)
Hi guys, I'm having a similar problem. I have the chirp that goes away at higher RPM's. I found this, what do y'all think? DIY: How to fix a squeaky serpentine belt on an Acura TL, MDX or ZDX - YouTube Should I go for it? I don't want to do anything unnecessary as it's been so damn come here, lately.
I should mention I had the timing belt service done about 18 months and 10,000 miles ago. |
I know this thread is old but i had the same issue and wanted to notate the fix. Import shop started by changing the serpertine belt, then the tensioner. worked for about a day or 2 then started back so they swapped belt with a different one which worked again for a day. Then read the service bulliten about changin out the bolts that SurfingScotty mentioned above. Didnt work. Then change out the AC compressor because using a stethoscope said the noise was the loudest in that area. Didnt work so lastly they changed the alternator which did the trick. The alternator i had on it was an after market once and the pulley grooves were very worn. If you have this and changing the belt, tensioner and bolts dont work try the alternator. Its about $400 but worth not having the noise.
Thanks for posting your fix and glad you got it figured out. I forgot to mention a follow up on mine. I bought the bolts but never installed them. Mine was just the belt. 👍🏼 |
