Third brake light out when engine on
Old Nov 24, 2019 | 02:21 PM
Denis Tsai's Avatar
3rd Gear
Hi, joined AZ to see if anyone has suggestions ...
The 3rd brake light on my daughter's 2008 TL does not turn on when brake pedal is pressed AND engine is on. It does work properly when when engine is off and/or when keys turned to ACC ON position. All LED's in 3rd brake light are fully off when this problem occurs, i.e. it's not a "partially dim" or "a few LED's are off" or "flickers" or "sometimes happens some times doesn't".
I've replaced the brake light switch which seemed to be a magic cure-all for problems with third brake light, but that did not help.
Any other suggestions or pointers for a basic DIY'er?
Old Nov 24, 2019 | 09:38 PM
csmeance's Avatar
The third brake light goes to a ground point after the light. If the ground is bad in any sort of way, it'll prevent the light from turning on. Sounds like the ground has some power going to it with the car on, but not with the car off. The ground is G501 according to the wiring diagram:
95oRANGEcRUSH
Jan 7, 2024 07:05 PM
larry04
Mar 20, 2011 07:46 AM
yankeeman515
Nov 28, 2007 02:17 PM
NitiNiteZ
Dec 12, 2006 03:18 AM
TLBaller
1G TL (1996-1998)
Nov 27, 2004 01:22 PM
