Teins are squeaking
Old Jan 25, 2007 | 10:09 AM
Maddizm's Avatar
Teins are squeaking
Has anyone had a problem with their Tein suspension squeaking? I had the coilovers installed on my 3G last year around July.. didn't really start noticin' the noise until it got cold. sounds like a small squeak whenever I go over anything. I tried to search out any threads that could solve this mystery for me but was unable to find an answer. There was one thread but i dont' think it applies to me. Is there something that I should check? suspension experts chime in please. Thanks!
Old Jan 26, 2007 | 11:04 PM
whatjones911's Avatar
I got this squeaking too! I would like to know what to do to fix it or if is it normal. It is alot worst in cold weather but it is always there.
Old Jan 27, 2007 | 12:24 AM
Laxplaya11385's Avatar
*phew* glad to know i'm not the only one w/ the problem. Mine only started happening recently w/ the cold weather.
someone help us!
Old Jan 27, 2007 | 12:30 AM
mr.almeida's Avatar
Put some grease on them... did you guys grease them before you put them on?
Old Jan 29, 2007 | 12:36 AM
Maddizm's Avatar
Grease them? Um... i don't think so... but where would i put this grease? I guess it doesn't really bother me, I just wanna know if it's normal or if it's detrimental in anyway to let it continue squeaking. I suspected it was the cold, cuz it's been pretty damned cold around coldest I can remember (SF Bay Area).
Old Jan 29, 2007 | 12:38 AM
mr.almeida's Avatar
http://forums.clubrsx.com/showthread...ease+coilovers
Read this thread maybe it can help you.
Old Jan 29, 2007 | 03:07 AM
ILLustriousUA6's Avatar
Feenin on some 20's
^^ yes.. my cuzzin had the same problem with his megans from his rsx-s... he applied grease and now, everything is fine..
Old Jan 30, 2007 | 11:14 AM
JDM5lugHatch's Avatar
Now with i-Vtec
Yes but the suspension is totally different on the RSX compared to the TL. The TL uses honda's famous double wishbone setup where the RSX is a Mcpherson strut setup. The TL doesn't suffer the same problems as the RSX.
You may be getting the noise from the spring and perch. Wrap the lower coil of the spring in a coil style wire loom. You can get it at Radio Shack and it should quiet down the coilovers a great deal. The only other noise you might experiece is the pillowball setup which is known to be noisy due to metal on metal or the shock doing it's job. Sometimes the shocks are just noisy themselves.
Old Feb 4, 2007 | 03:30 AM
Maddizm's Avatar
Thank you JDM... that's the answer I was kinda hoping to hear... I didn't want to hear that there was something wrong with my coilovers or the installation. But I'll check it out.
lanechanger
Oct 13, 2015 10:56 AM
2012wagon
Sep 29, 2015 04:21 PM
jmaxima03
Sep 27, 2015 10:22 AM
4drviper
Sep 23, 2015 07:42 PM
njresendez
Sep 21, 2015 11:23 AM
