Tail light
Old Jan 23, 2018 | 07:18 PM
Joeslow's Avatar
6th Gear
Unhappy Tail light
im having a odd problem with my 06 TL. I thought driver side tail light was out and one of my license plate lights. So bought all new bulbs and replaced them. Thought I was all good with the exception of the burnt out license plate light. Figured bad socket and I would fix another day. Then I closed the trunk. Tail light goes out and license plate light turns on. Pulled trunk apart again. All wiring is seemingly intact, factory wrapping with tags etc... has anyone experienced anything like this before? Any advice would be appreciated
thanks Joe
Old Jan 24, 2018 | 08:10 AM
peter6's Avatar
- Tail lights are LEDs. You mean turn signal bulb? Or reverse light?
- "bought all new bulbs and replaced them" - so you replaced that license plate light, but it didn't work, right?
- now after smashing the trunk license plate light works, and taillight doesn't?
How sockets looks? Are they melted, corroded, green-ish, anything?
Old Jan 24, 2018 | 11:37 AM
Joeslow's Avatar
6th Gear
Replaced turn signal bulbs back up light bulbs and licencse plate light bulbs. I replaced didnt smash anything. Taillight was not working on drivers side and no license plate lights. So purchased for both sides and trunk. Put the car back together and everyting worked with the exception of one bulb for license plate with trunk open car running lights on. Close trunk both license plate bulbs now on and no taillight.... All sockets looked new as well as plugs and wires. Used bulb grease on all of them. It has to be a wire or wires that are pinched or frayed somewhere. Hope its a ground easier to fix
Old Jan 24, 2018 | 11:43 AM
BreezyTL's Avatar
Sounds like you have the right idea. Look for bad wires?
Old Jan 24, 2018 | 11:48 AM
The wire loom along the trunk is probably problematic.
chrisbrito09876
May 5, 2020 02:12 PM
JTS97Z28
3G TL Photograph Gallery
127
Jun 1, 2019 08:37 AM
clavodulce16
Dec 20, 2007 12:23 PM
THTL
Sep 19, 2007 09:45 AM
LoveMyTL-S
1G TSX Photograph Gallery
51
Jan 31, 2007 06:55 PM
