Switch Blade Remote
Switch Blade Remote
I bought the Switch Blade Remote from FLBusa along time ago. I finally went to Acura to get my key programmed and cut. The programming went fine but they stated they cut the keys and it works but only one direction. The key will only work on one side but on the other side it doesn't turn the ignition or lock on door. Any ideas?
RPF1+RS3 FTW
Sounds like your dealer messed up the cut. I had mine cut at Acura of Santa Monica and it works fine both sides. The only person who could probably help you at this point would be Marcus of Heeltoe Auto. He is a switchblade key master. If they did botch the cut, chances are you will need a new key which is going to cost some money. Anyways contact Marcus, he cuts and mills switchblades.
SinCityTLX
10-07-2015 01:24 PM
xsilverhawkx
09-28-2015 06:51 PM
